Version: 2.0.22
Plantilla: iggstation
Tengo una duda con este paso: ¿Que significa? ¿Hay que aherlo obligatoriamente?
#-----[ DIY INSTRUCTIONS ]------------------------------------------
For additional Security please look that you will find this code part:
if ( !defined('IN_PHPBB') )
die("Hacking attempt");
in _all_ *.php files wich are uploaded into the folder includes/ of your phpBB installation.
You can find this line just after the beginning of the file (<?php). It should be placed
directly after the comments before other PHP Code is written. Some Mods have forgotten to
place this line in Includes Files and then someone has the possibility to just attack one
of that file without running other Board files. If you have questions to this step feel free
to ask in our Forum at www.community.cback.de for Support.
Saludos!
