error al loguearme o registrar usuario
JPardo
Mensaje por JPardo »
URL: http://www.josepardo.org
Versión phpBB: Versión del Sitio: 3.0.10
MODs Instalados: Ninguno
Plantilla(s) usada(s): skyblue
Servidor: pago
hola, cuando intento loguearme, registrar un usuario, crear un post, me sale el siguiente error:
Strict Standards: Non-static method utf_normalizer::nfkc() should not be called statically in /home/nkqozowyun/public_html/josepardo.org/includes/utf/utf_tools.php on line 1663
[phpBB Debug] PHP Warning: in file [ROOT]/includes/session.php on line 1035: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/utf/utf_tools.php:1663)
Warning: Cannot modify header information - headers already sent by (output started at /home/nkqozowyun/public_html/josepardo.org/includes/utf/utf_tools.php:1663) in /home/nkqozowyun/public_html/josepardo.org/includes/functions.php on line 4682
Warning: Cannot modify header information - headers already sent by (output started at /home/nkqozowyun/public_html/josepardo.org/includes/utf/utf_tools.php:1663) in /home/nkqozowyun/public_html/josepardo.org/includes/functions.php on line 4684
Warning: Cannot modify header information - headers already sent by (output started at /home/nkqozowyun/public_html/josepardo.org/includes/utf/utf_tools.php:1663) in /home/nkqozowyun/public_html/josepardo.org/includes/functions.php on line 4685
Warning: Cannot modify header information - headers already sent by (output started at /home/nkqozowyun/public_html/josepardo.org/includes/utf/utf_tools.php:1663) in /home/nkqozowyun/public_html/josepardo.org/includes/functions.php on line 4686
no he hecho ningun cambio o instalacion
los del hosting me dieron esta respuesta:
Hello sir we do not support website issues you will need to open a support with phpbb and ask them what is your issue with the website as our server is running perfectly fine with no issues ... you also might want to check your websites template if it support php 5.4
Última edición por ThE KuKa el 05 Sep 2013, 00:23, editado 2 veces en total.
Razón: Añadido BBCode CODE
Versión phpBB: phpBB3 (3.0.8)
Plantilla(s) usada(s): Skyblue
Servidor: Servidor Linux gratuito
Actualización desde otra versión: 3.0.7-PL1
Edad: 52
Re: error al loguearme o registrar usuario
Prueba esto...
Abrir archivo /includes/startup.php Buscar - Nota: Esto puede ser una búsqueda parcial, y no una línea entera.
error_reporting(E_ALL & ~E_NOTICE & ~E_DEPRECATED);
Reemplazar por - Nota: Reemplazar las líneas a encontrar por las siguientes líneas.
error_reporting(E_ALL & ~E_NOTICE & ~E_DEPRECATED & ~E_STRICT);
micontre
Edad: 61
Mensaje por micontre »
mira esto hay tienea la solucion (al menos para el usuario que habrio el tema con el mismo error)
https://www.phpbb.com/community/viewtop ... &t=2163652
Mis datos | Mostrar
URL: http://imaginewal.com/
Versión de phpBB: 3.1.6
JPardo
funciono bien, gracias por el dato !!!
lo que no comprendo, es por que salio ese error?, yo no hice ningun cambio, funcionaba bien el foro y de la nada sale este error.
ThE KuKa escribió:Prueba esto...
Edad: 52
Es por la versión de PHP instalada en tu servidor y de parte de la configuración de PHP.INI si no me equivoco, en phpBB 3.0.12 y/o phpBB 3.1 esto estará solucionado (creo recordar).
